LastDollar
- Nov 5, 2010
- 117
Re: restoring my old new 71 starcraft center console
I didn't see in your postings what you did to repair the transom.http://forums.iboats.com/attachment.php?attachmentid=60555&d=1279594367 I would check that some one didn't replace the transom board with treated plywood. The console look sharp
I am taking it to the lake on nov-19 which is my birthday.The floor is loose still, so i will move all pieces to truck and check for leaks and mark them with spray paint can,hopefully there will be few.Then again the boat might fill up before i open my first beer!Ill take photos that day as it happens.Then ill put down foam and floor, screws and wiring for helm,then go fish out side the tires of the marina, with my transom mount trolling mtr,for my b-day im turning 40.Im bring some water proof jb weld along with me that says can be applied under water.So ill be rubbing that stuff all over anything that starts gettin wet.ill also have a high output bildge pump hooked up along with two batteries. One more thing,ill be running wood along the inside sides for more stability controling flexing.
