Resurrecting TJ60TLENE
tloc1000
I broke one of the bolts so I'll need to get an ez out. Any tips on that?
So what's the verdict? The middle cylinder is slightly scored. Is it ok or do I need to hone it? How can I tell if the rings are stuck?
I haven't checked the head to see if it's warped but I had planned on sanding it down as described in some other posts Ive been reading.
Motor needs to come apart.----Yes your head is warped !----They all are after years of service.
flyingscott
Before you do anything scrape the carbon off of the top of the piston. You should see a part # and hopefully the size is not on it. Stock pistons do not have a size on them oversize pistons will have the size on them.
