Retorquing Head Bolts
bikemtn
Mercruiser 3.7L
What is the correct process to retorque the head bolts? Do I loosen them first? I have a maunaul, but it just says to retorque them after break-in at their noted specs, but nothing about loosening them first.
HT32BSX115
Re: Retorquing Head Bolts
(loosening?) Short answer is no.
Just put a torque wrench on it and start with #1 and torque to rated spec and the stated pattern.
Cheers,
Rick
bikemtn
Perfect....thanks guys! I did not think I would have to loosen them, but read on some websites to looosen like an 1/8th of a turn. That did not seem right, so I had to ask the experts here on the forum.
bikemtn
Stupid question.....
Do I need to get a special socket for the bolts under the rocker cover? Nothing I have will fit under the rockers. I tried to find the shortest/thin walled sockets I have...
Fishermark
Sometimes you need to loosen the rocker arms to get access to the head bolts. Just a FYI - did you oil beneath the heads of the bolts before torqueing them down? If not, your torque values are probably not accurate.
bikemtn
I will try that...
I put a torque wrench on outiside bolts just to see how tight they were and they turned with 35#...So needless to day they need to be retorqued. I just want to do it correctly.
thanks
Fishermark
If they turned with 35 pounds pressure then they were not torqued right to begin with. No way they loosened up that much. :eek:
bikemtn
I agree. I am not really happy with the workmanship the people did on the rebuild. I would take it back to them, but my warranty expired, and I think I could do a better job anyway!!!
bikemtn
When loosening the rockers should I put #1 tdc when I tighten them back up?? I do want to bend a rod or something.
I think the specs for the rockers are 20#?
bikemtn
I went ahead and loosened the rockers and was able to torque the head bolts....and they were in fact a bit loose. I made sure to tighten the rockers back to spec per my manual (20#) when the valves were in the appropriate position. A word to all the folks that are on here and do not have a manual....Get one!! They are cheap and save you a ton of time!!!!!:cool:
achris
More fish than mountain goat
... A word to all the folks that are on here and do not have a manual....Get one!! They are cheap and save you a ton of time!!!!!:cool:
Amen!!!
