Re: REV clock
If you got the original control box with your motor, there's a 3-prong plug (might be covered with a rubber boot) right under the keyswitch, and a plug & play tach harness is available (got mine at BPS). if not, or you can't find the harness, just wire the tach 12V pin to the purple wire (keyswitch terminal A), the GND pin to black (keyswitch M), and there should be a gray wire in the engine wiring harness for the SND pin.
