tashasdaddy
- Nov 11, 2005
- 51,019
what you idle rpm. also shift quickly not slowly.
tashasdaddy said:what you idle rpm. also shift quickly not slowly.
Texasmark said:I'd think it would be just the opposite. Rev gear on Mercs (the one's that I know) is a cog-tooth arrangement where the gears have vertical sides. That means that the clutch dog's teeth have to match exactly the R gear's teeth and then it can engage. If your rpm's were too high then it would be harder for the "pins and slots".....teeth , to line up.
Totally agree on the "snap" of the shift lever into gear.
Lastly, your shift linkage may be adjusted (maladjusted) a little in the direction of F which would reduce your leverage in cramming R home.
Mark
Tony said:Texasmark said:I'd think it would be just the opposite. Rev gear on Mercs (the one's that I know) is a cog-tooth arrangement where the gears have vertical sides. That means that the clutch dog's teeth have to match exactly the R gear's teeth and then it can engage. If your rpm's were too high then it would be harder for the "pins and slots".....teeth , to line up.
Mark
Thank You Mark.
That was very informative. I will try to adjust the linkage and post the result.
Thanks ,
Tony
PROBLEM SOLVED!
Adjusted the linkage as suggested. That was all it needed. Now the reverse gear engages without hesitation.
Thank you very much
Tony
