reverse rotation starter question
b2krawler
Here is what i plan on doing, I am replacing my blown 351 in a mid 80s natique, the blown 351 is stanard rotation, LH prop, (seems like an oddball for a mid 80s natique) and the starter is also standard rotation and engages the flexplate from the engine side (not the trans side). <br /><br />The new 351 is reverse rotation and, has a very similar tranny but the starter engages from the tranny side since it is a reverse rotation. <br /><br />I plan on using the old tranny with the newer engine, and switching to a RH prop. I already know how to switch the flow of the trans pump for the newer RR motor. Can i still use this trans with this motor and buy a reverse rotation starter, is there such thing? Im not a boat guy, so its all new to me.<br /><br />I would use the trans that came with the new motor (starter on trans side), except I think i will have clerance problems with the starter and the engine cover.<br /><br />Hope I made sence<br />thanks Shawn
tommays
Re: reverse rotation starter question
i can take a picture next week of how an orginal 1977 351 reverse motor is set up but cant get to the boat till then<br /><br />the newer manifolds required raiseing the engine box also<br /><br />i will be home again about the 18th<br /><br />tommays
snapperbait
Yes & yes..
Bt Doctur
just remember on a standard engine side install ,use a standard starter for std rot.and visa versa<br />on an engine W /rear entry(trans side)the starter is a standard rot. for reverse rot. and reverse rot. starter for standard rot. motor.
