Re: Reviving 1956 Evinrude Fleetwin 7.5 - Pressure Tank Issue
			That in itself does not indicate a lower unit leak. You are going to get that when you run a 24:1 gas / oil mix on one of these old kickers in a barrel.
You know, I think that lower unit was stored dry.  That little bit of oil that cam out with the water was more like the surface of the water in the barrel than lower unit oil.
As you can see, I put the motor in the barrel one more time before the maiden voyage.  I got the same slick, which looked nothing like the LU oil I added.
With that I also don't, any more, think that I have a lower unit leak.  I'm no physicist, but here'e what I think happended:
A lower unit, full of air, goes into the water, with no seals on the drain/vent screws.  Air is constantly trying to escape and suck in water.  Ad some vibraton to boot, and you have a situation where water is drawn in, otherwise good seals not withstanding.  That water, of course, included some of the same oil I was seeing on the surface of the water.  Result: a smattering of water from the drain hole, with a coulpe of drops of blackish oil on top.  Makes sense to me.
As to the maiden voyage:  The motor ran good.  It was a little weaker than I had hoped, but not bad.  I discovered that I didn't tighten well enough that sleave compressing the high spead needle packing bushings.  I found the sweet spot for the high spead needle.  Then, as soon as I would let go of the knobb, it would slowly rotate from the vibration.  I don't quite get the physics on that one, but the solution is simple enough.
Just to be safe, I'm going to drain and check the oil once I pick up more lower unit oil.
Thanks again for the help.
