Right plug
ericcarr2000
Ensign
I am in the process of reporting my 1990 sundancer. I know the casting number from the heads are 3917215. Can anyone help me out to find the correct spark plug for it?
tlt383
Those heads cross to 68-69 closed chamber big block heads, pretty desirable in the auto world, anyway, stock was AC Delco R43. If you have a pretty high compression motor and want to run a cooler plug, an R42XLS would work.
alldodge
That casting number are for 396 and 427 not a 454/7.4
Ayuh,..... AC Delco, MR42T,.....
The M is marine, which is an alloy body,....
The XLS are much longer plugs for the Vortec heads,....
