Rochester Carb gaskets
Josh P
ok , so i got a new boat don and achris have been helping me figure out what i need to change the shift cable and do trim senders. while i wait for the parts to arrive i would go through the carb, it would miss at idle with choke open, with choke closed would idle fine other than being rich.
I rebuilt the carb found some nasty stuff in the bowl.. Now my kit did not come with the right gasket to go to the carb base to the factory adapter plate then i also need adapter plate to manifold gasket. Any where i can go to get factory numbers to order them here from iboats, as their description arent very good..
I will get the serial number tonight, the carb is a 2GV model on the ford 302 188 hp 888 drve setup
achris
More fish than mountain goat
Re: Rochester Carb gaskets
Adapter gasket - part# 27-70143
Base gasket - part# 27-70142
Josh P
man you are a life saver. i appreciate all your help i really do..
Josh P
sweet iboats has them in stock will order those tommorow with my trim senders... thanks achris you are the man..!!:D
