Re: "Rod Knock" Turns out to be top cylinder piston slap - what caused and how to fix
So the question now is build or bore?
Just to be sure about the blue tint or not on the piston pin and bearings I included a shot of them. The cylinder shots are after 28 passes with the ball hone.
The cylinder is about 0.00075 out of round (bigger vertically). That is also the case with the two good cylinders. It is also tapered about 0.001 being bigger at the top (spark plug end). That is also the case with the other two. The middle of the bad area is now re-surfaced (scratched up). I could hone some more but when I got to .001 OOR I decided that was as far as I wanted to go.
The dial bore gauge is pretty neat. I set the dial to read 0 on the small dimension (horizontal) of cylinder 2 about an inch down from the bottom. My calipers measure 3.3735 which is the same as when I used the telescoping gauge so I guess the problem with the measurement being under was not my ability to use the telescoping gauge but the calipers themselves. The biggest micrometer I have goes to 3 inches - not quite big enough. My measurement of the ID of the connecting rod on the piston side was exactly what Fazt posted some time ago for a 1991 90Hp engine so the calipers might be ok for that dimension.
If I build, I suppose I should clean out the ring grooves for the other two pistons? They are free. I can afford to break a ring since I ordered rings and clips for the new piston no knowing that they were included with the quicksliver piston which is a little different that the others - the original pistons had well defined rings around the outside.
As for the loctite, I wasn't asking about bolts in the crankcase (actually I thought I was supposed to install those dry) but other bolts that the manual specifies locktite for. A mechanic at a local shop also used the term "oiled in" so I guess I should put two cycle oil on them. I called to ask if they had the bolts and he told me to re-use the old ones.
Thanks for the info on the clip orientation, I had not heard that before.
