Howdy, It should tell you once fully warmed up, and the choke is FULL OPEN (and out of the picture), that the choke may be all or part of the problem!yes, after 30 min of use, the "sputtering with light throttle is gone"
so what does that tell me? tells me carb doesnt need cleaned? or more likely needs cleaned? i really want this fixed
possibly. But not always. Your accelerator pump might not be providing enough fuel as you open the throttle too......i see - i think i follow you - and because my choke is opening up in full BEFORE the engine is warm, that might be why i have that stutter?
so...how would i adjust that
Exactly...this is why you have a choke issue. It's not adjusted properly.well crap - when the engine is warm, I don't have that low throttle bog down issue - its a catch 22
Yes lets go ahead and close this topic and keep the conversation within the other topic. One problem would be if we moved any to all of these posts over to the newer topic, it would be just one big mess to figure anything out as there would be about 58+ posts and a lot of them would be close to duplicate posts.I want this closed I opened a new one w/ a more accurate title, here:
http://forums.iboats.com/forum/engin...putter-and-die
its got much better info
