marvin the minnow
- Jun 16, 2010
- 85
Re: RPM Question
Yes.... my concern is not speed but a healthy motor.
1980C, it's not trying to get more speed so much as gettng to motor closer to its rated wot rpm.
for the health of the motor.The motor will use about the same gph(gallons per hour) at wot wheather its turning 4800 or 6000 the key is running within it's wot rpm while producing a good speed.Speed at a given rpm determines mpg gph devided into miles per hour.
I think its worth trying. I just don?t want to start spending unnecessary funds on props.
The 4 blade should do better overall than your typical 3 blade.Should resist venting and have better slip numbers.The 4 should give better control around the dock.
A 3 blade same pitch could increase rpm but will likely have higher slip numbers.
could improve speed probably a toss up.
Pontoons do produce higher slip numbers.
Decreasing diameter on a pontoon risks venting problems and increased slip.
1980C, increasing wide open throttle rpm doesn't burn more fuel wot gph remain relatively constant if you lose wot speed mpg goes down if you increase wot speed mpg goes up. but gph remains relatively constant.
when you refer to slip are you refering to caviation?
that sounds exactly like what I predicted..you dropped 1 pitch but went to a 4 blade hence you should have the same WOT RPMs as the 10P 3 blade. which is why I suggested going with the 3 blade 9P prop. If you are around 4800 RPMs you should be ok though, that is kinda on the low end but should not harm your motor.
