JimS123
- Jul 27, 2007
- 8,282
Re: Rule Bilge Pumps....who sells them the cheapest?
Wait a minute.!! With that scenario why do you even need a float switch?
When its on the trailer just pull the transom plug and problem solved. When its in the water, if you get water in the boat, just turn on the pump manually. Unless you're asleep, you will find out pretty quick that you have water in the boat.
Regardless of them killing the battery, the worst part of that dumb auto pump was the nerve racking wizzing sound every 2.5 minutes.
My boat is trailered and only on the water for a day of fishing etc....then pulled and trailered home. So I'm not concerned with a pump failure while the boat is out of the water.
