Run engine on stand
77searay197
​ ​​​​​ i bought a engine run stand to in my boat engine I built before I install it to make sure it has no problems. I have a Yamaha sterndrive. Does anyone know how to wire it to the battery to make it start and run? Here’s the schematics
+12 volts to the purple wire for ignition, jump the s-terminal on the starter to crank (yellow with red tracer).
run motors all the time that way.
BTW, didnt even have to look at your schematic. wiring colors are standard. [h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
77searay197
So do I not need to wire up and use the ignition switch on the run stand to start it?
you can if you want, I use two wires with alligator clips on the ends
Nope,..... Just use jumper cables to the starter, 'n a jumper lead to the coil's (+) tiny terminal,.....
Silvertip
To stop the engine disconnect the battery cable. No juice, no run!!
