running lights won't work with Ford truck
bruceb58
Re: running lights won't work with Ford truck
You won't need a module for your Ford truck so don't worry about that.
demsvmejm
Master Chief Petty Officer
paulie0735 said:
should take them 15 mins to half hour max. Good luck.
Only if you want a hack job.
If the job is done correctly, with proper testing and solid, secure and protected connections, expect up to 1 hour. Or the shop may use a "T" connector which would cost more, but is a better (in my professional opinion) installation of a flat four connection.
demsvmejm
Rick_Criswell said:
My ford (99 F 150)has fuses for the truck lights. One for each side, under the dash. And one for running lights
It also has 3fuses for the trailer light wiring under the hood in another fuse box.
You should check the fuses under the hood.
DANG you beat to this possibility. I love it when a customer comes in with the complaint of turn signals, brake lights or running lights out and they've checked all the fuses. When I check the fuses, replace one and show the customer that the lights now work, they look at me like I'm a genius. I'm purty schmart, but I'm not no genius (read with redneck accent:)).
Make sure to consult your owners manual. Since all your lights work properly with another truck, I wouldn't worry what the 5th wire is for. The problem is evidently with your truck.
