Re: Running Pre-Mix Motors Dry
Add fuel stabilizer to the fuel, run the engine until you know it's been drawn into the engine. Fog the engine. Drain and refill the lower unit. Store the engine vertically. Draining the carbs leaves air and oil residue that can cause gum and varnish. If they are full, no air, and with stabilized fuel, you will be set to go in the spring.
