I am planning on mounting/installing a transducer in my 27 foot searay for my lowrance hds5 unit and was wondering what is the best way on doing it. I do not want to drill a half inch hole in the transom just so the connector could fit through. I was thinking on cutting about 6-8 inches off the end of the connector , running all the Wire through the transom and dash and then re connecting the cut off connector / plug. I am good with soldering work and electrical work in general so it's not a problem for me. How does everyone else run their transducer wires? Also I was looking into purchasing the Navico HST-WSBL 83/200kh sonar transducer for the hds5 , to my knowledge and research it is the only one that will work with the lowrance hds5 units. Are there any other ones that I don't know about that are better? Thank you in advance.
