running without bypass valves -- is this OK?
scmutiger
1992 Evinrude V4 90 HP
124 pounds of compression exactly on all 4 cylinders, and a good stream from tell tale, VRO bypassed, Champion plugs:
Cylinder #1 was running hotter than it should. I removed the bypass valves and springs, but left the thermostats in place. It runs much cooler now. Will this setup cause any problems?
Thanks,
PS....not that is matters much, but here is my gas recipe of choice:
Chevron 87 octane gas
Quicksilver (Mercury) TCW3 Semi Synthetic oil
Yamaha Ring Free
STA-BIL Marine fuel treatment
Joe Reeves
Re: running without bypass valves -- is this OK?
The thermostat bypass valves are an essential portion of the engine cooling system. Without them, the thermostat purpose is cancelled out. This will result in piston damage and necessitate rebuilding the powerhead.
Replace the thermostat bypass valves. Test and replace the thermostats if needed. Drop the lower unit, inspect the water pump and replace if needed. If engine still runs hot, check the water deflectors.
There are no short cuts and what you are attempting is referred to a patch work which usually turns out to be an expensive mistake.
(Thermostat Purpose)
(J. Reeves)
Many engines are considered high performance engines and demand a thermostat(s), and many smaller hp engines also require a thermostat for the following reason. The pistons actually distort/twist off round when running. The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperture to compensate for the distortion.
With the thermostat removed, the difference in temperture between the inside the cylinder and the water jacket quickly reaches a point whereas (in effect) you have a oblong piston running up and down a round cylinder, or vice versa. Bottom line is without the thermostat, the piston and cylinder wall could be damaged in a short period of time.
The thermostat in your car isn't there simply to have the heater function properly..... think about it.
The engine must run a an approximate temperature of 143?, somewhere in that area.
(Water Deflectors)
(J. Reeves)
Water deflectors are actually lengths of 3/8" outside diameter rubber hose, installed between the top cylinder and any cylinder beneath it, and also between the bottom cylinder and the block. The purpose of the deflectors is to have the water follow a definite path around the cylinder walls. Unfortunately the deflectors between the cylinders will at times swell sideways due to either a previous bad overheating problem, or simply due to age and salt corrosion. This causes a water flow restriction which usually allows the water to cool sufficently at low rpms but not at the higher rpms.
This hose material can be purchased reasonably at any automotive parts type store if you care to make your own, or you can purchase individual deflectors at any Evinrude/Johnson dealership at a somewhat higher cost.
Removing and installing them can be a hassle at times, but not always. I use a sharply pointed scribe with about 1/4" of the tip bent at a right angle whereas I can reach in, jab the tip sideways into the rubber, then yank it out. It's necessary to clean the seating surfaces where the ruber contacts the block with a small rat tail file to eliminate salt deposits etc. When installing the new rubber deflector, coat the deflector and the metal surfaces with WD40 which will act as lubrication to allow it to go in as easily as possible.
Make sure that you insert something into that deflector area before cutting and installing the deflectors if you make your own so that you will be certain that they are the right length and also that they will be seated properly. Usually a very small amount will be left extending about the block sealing area..... simply cut the excess off with a single edge razor blade.
scmutiger
I was afraid you were going to say that.
Thank You,
scmutiger
