Runs Well, Can’t Reach Top Speed??
99yam40
so are you trying to say full retarded spec is not with throttle at idle?
jimmbo
What I am saying, is that on every 2 stroke I have ever seen, the Carb(s) are fully closed at Idle, and the Idle Speed is controlled strictly by the Spark Advance/Retardation. A change in Prop Pitch will load an Engine differently, and will affect where the Timing is, to attain the correct in Gear, Idle Rpm
99yam40
on all 2 stroke motors I have ever worked on ,outboard, chaisaw, weedeater etc there is a idle speed adustment srcew that cracks open the throttle plates to set the idle speed.
just like on my C40TLRX shown in the pic I posted there is a spec for timing while at idle, and you do not change the timing to set the idle speed, you adjust the idle speed screw on the carbs
jimmbo
No 2 Stroke Outboard I have ever seen the past 60+yrs has ever had an Idle Speed Adjustment done at the Carb.
99yam40
apparently, you have never worked on Yamahas.
maybe the old johnyruds is what you are talking about moving the timing plate.but those were way back 30 or40 years ago
