rusting manifold/engine block
Schmoe
Since I've owned my boat, '99, I've always drained the exhaust manifolds and block for winter storage. Put in some antifreeze in the hose at the water pump and be done with it. But, got to reading around in here and made me think of something that's been on my mind. I hear a lot about exhaust manifolds rusting out. Because of this, after I take the boat out of the water and get ready to store it, I go ahead and drain the manifold and the block with the thinking that keeping water out of them has got to be better than letting them sit full of water for a week or two at a time. I'm wondering if this helps prolong the eventual rusting out of the manifold. On my engine, the exhaust manifold is still the original, factory installed one. I do notice small bits and pieces of rust coming off the exhaust manifold that gets trapped inside the hollow 7/16 brass plug. From what I've read, that is normal, or to be expected. But what about the block? It doesn't seem to have any telltale signs of corrosion. Is there a difference in the metal? You think I'm wasting my time draining it out after use? I usually take the boat out at least once every two weeks throughout the summer, which is from May to September around here. When not in use, the boat is stored dry in a metal enclosed stall.
I had also thought about creating a piece of pipe with the 7/16 threads on one end and make like a drain extension coming off of the exhaust manifold, if you will. On the other end, have something like a valve on it that I can easily open and shut to drain the water instead of having to take the plug off every time. I don't know, just thinking..............
Schmoe
Re: rusting manifold/engine block
Fresh water. Hmmmmmm, never thought of that. That would expose the metal to more oxygen than opposed to being saturated with water. There's more oxygen per unit volume in air than in water. That did cross my mind a few years ago, but never really thought more about it. Unless there would be a way I could totally dry it out, but that ain't going to happen. Wonder what the average life of the manifolds are with fresh water?
Lodgepole
For my part, I like to fill everything I can with antifreze for winter storage. That way, you get rust protection instead of wet air capturud for the winter. And right, you get less rust in boating season with water inside instead of wet air.
Howard Sterndrive
Cast iron will last forever under water.
But expose unprotected cast iron to the air and it rusts like mad.
Ayuh,... Considering there ain't much Saltwater in Oklahoma,... You have Nothing to worry about...
Manifods,+ motor blocks will last til 'ell freezes over boating in Sweetwater....
My motors are stored Drained,+ Dry in the winter...
In the summer, Yes, I think you're wasting your time draining after each use...
Btw,... Those are 1/4" Pipe threaded plugs, Not 7/16" threads...
And, your extenion Idea isn't such a Great 1,...
You won't be able to knock the crap out of the way when you do drain it....
Stick with what you have...
Mkos1980
My fathers 800HR 1990 350 BlueWater inboard Mercs look perfect inside and out with freshwater. Risers and manifolds are all origional also.
