- Apr 17, 2002
- 71,418
Thanks for the additional input . It's been unusually warm this winter in Oregon so I'm going to get the engine out of winterized mode soon . Will running the engine out of the water with muffs be sufficient to test the condensation theory ? If so , how long should the running time be ? Thanks
Ayuh,.... Yer Test might rule out cracked cast iron parts,.......... or not,.....
Ya really need to run the motor up to temp, 'n then run fairly hard, workin', Laborin', to build motor oil heat to steam off the condensation,...
But,.... If ya run it, 'n the oil Level is stabil, it's probably not cracked cast iron,....
If the oil Level rises, ya, ya got problems,...
