Re: Safest way to remove control cables
Disconnect them at the engine end and then see if you can remove the remote control without disconnecting them at that end. If you do need to disconnect them at the remote, take the lower part of the outer cover off the remote control.
Click the thumbnails, then click again.
At no time should the cables have a bend with a radius less than twelve inches.
