salt water in single cylinder
Scott06
So I have a line on a cheap 2003 supposed mercruiser 090 block running engine, no manifold. Does the 090M stand for marine. How can I tell if it is marine and not just GM?
090M is for metric. For some reason they used metric fasteners on some of the 4.3 blocks... in true GM fashion only some of the threads are metric- starter bolts, flywheel cover, and front/side motor mounts. I bought about $40 worth of SAE bolts to convert when I did my repower.
If you are buying a complete used engine doesn't make any difference, only when you are mixing and matching parts is it an issue
Never found an answer as to why they mixed metric and SAE threads on the same block. I can understand one or the other but both on the same block makes no ducking sense
Lou C
There are no “marine” blocks or heads only add ons like the head gaskets, core plugs etc. the M refers to the us of some metric fittings. In that case if you use it be careful with threading in fasteners in fact you might want to buy an SAE/Metric thread chaser set so you can check them first!
Lou C
If you wind up going with it & still have those one piece exhaust manifolds it’s a good time to ditch them for the 2 piece conversion. Barr marine makes a nice one check out Lighthouse Marine in Riverhead…,
beruken
Thanks. Yes, I have new 2 piece on my baddy rn. It is just the long block so I have to bring everything over. My only concern right now is the compression. That motor was an MPI with electronic ignition. I had carb and distributor with thunderbolt ig. I assume distributor will drop right in.
beruken
Is there any way to verify it is actually a mercruiser and not stock GM build?
Scott06
It will have a mercrusier serial number tag riveted by the starter
Mercuriser buys gm base engines/ long block and builds them out so it is just a gm truck engine with minor tweaks
beruken
So I found a reman with a decent sale price ongoing but want to know if anyone has experience or knowledge of United Engine I believe out of California but not sure. They don't post their corporate address.
Lou C
I’m very suspicious of ANY of those places. Try a local rebuilder, ask local marine mechanics for recommendations, who do they use. The idea of sending off $3500 to a place I've never seen people I don't know is unsettling. It's too bad you can't get any more new 4.3s, the only GM marine engines you can still buy new AFAIK are the 3.0 4 cyl and the 5.7 V8.
nola mike
many on here have had luck with Michigan motorz. I haven't purchased an engine from them, but have bought a few parts, and spoken with them about technical questions, they were very helpful.
beruken
I hear ya Lou. They have a sale price going from 2.4k to 1.7 rn What they say sounds good but you never know. Just don't want to dump another 3.5 k into it bc you don't get that money back and I am tired of working on stern drives. Haven't been able to find anyone regionally that does engines either. Time for an outboard. Been seeing more of newer cabin cruiser style boats with outdrives. Single ones too. Outta my price range though!
Lou C
I would look at Marine repair shops on the South Shore of LI, there are many there that I’m sure do inboard repowers I’d ask them who they use…what you need is nothing exotic just a 4.3 Chevy Vortec! Outboards are easier IF you start with a fairly new one but to do a complete repower is VERY costly.
kd4pbs
If you go with a bulk rebuilder, search deep for reviews. None of these places will create bad reviews, but they are notorious for inflating their own ability with fake positive reviews. If you read a bad review, you can trust it.
Outside of a crate engine from GM, find a local shop who rebuilds engines.
These bulk rebuilders will notoriously do things to cut corners that are janky at best. Their version of "good enough" means that the engine will probably last just long enough for the warranty to expire.
beruken
Thanks Guys. The locals use Jasper engines or they don't have anyone specific to recommend :rolleyes:
kd4pbs
It would be worth it to travel to your next closest large city to find someone to build it. You'd save money on shipping, and also save money in the long run by not buying something that was put together shoddily.
The boat I've been working on all summer had a Jasper reman in it when the wife bought it. It was not very old (2018 rebuild) and was freeze and saltwater damaged beyond repair. Judging by the lack of any noticeable wear, I estimate the poor thing had just a handful of hours on it if even that much. While I'd say that they did a fairly decent job on this engine, I don't know that I'd call it a good job. The pistons and rings were of decent quality and were a new, matching set. The main and rod bearings were of decent quality. They did put the proper "marine" cam in it. The one Mercruiser or Volvo-Penta would have used, a GM '7395 cam. The heads were genuine GM '906 Vortec heads. The block was an 880 casting. The crank was not worn, and was turned .01" undersized. I measured less than .0001" variation between the journals and bearings - almost unmeasurable. The finish on the crank journals and main bearing surfaces were good. I re-used the cam and crank.
As for what I did not think was good about this engine, Jasper had mixed and matched some different style connecting rods. They did at least resize them, as some rods had caps that were obviously not married to that rod it's whole life. Same thing with the roller lifters - some had some patina on them, others looked brand new. Even the pushrods were not matched but were different styles. The valves were not stainless steel. There was very little paint on the engine, but I am not sure if that's something that they leave for the mechanic to do since there's no telling what color it might should be painted. Does any of this matter? Maybe not so much in the end, but it is not the way I'd go about it.
I believe that it all depends on who was doing the build as to whether or not you get a decent engine from these bulk remanufacturers. I know for a fact that I'd never get one from them that has as much attention given to doing it right than I would. But there are a couple machine shops within 60 miles of me that I'd use if I no longer had the ability to ensure the clearances are correct, the parts are good (and matching!) and assemble one myself.
This is something people should spend a bit more money on to do it right or get it done right. Pinching pennies here will only lead to headaches in the near future.
