Re: Same ol more holeshot!
I can post the picture. In the mean time, Having run several of them I knew what to expect. Additionally, I pulled up the OMC picture that is popular on here and it was not right for my application.
Your best bet would to buy a ported "new prop" when you buy it. Second would be to go to a prop shop and have them do it if you find a non-ported prop you think you'll like and after trying it decide to have it ported.
In porting things to consider are prop ribs that can get in the way, where to put the hole with respect to the blade, how large a hole to drill, and having a suitable drilling machine with proper fixtures to hold the prop and drill through the nickel (tough stuff), and each hole should be in exactly the same place with respect to that blade to prevent uneven rotation or vibrations from non-uniform loads on the blades and all.
Yeah, I never drilled one before, but was careful, and was lucky I guess. Got it right the first time.
There are plenty of ported props out there. Since you aren't worried about top end the 4 blade non-ported could work, but again, the thing I like about ports is that it unloads your engine at the highest stress point......when the boat is in the water and the skier is in the water and you are trying to get the engine to spin the prop to get you going. Porting just takes the pressure off the engine, allows it to spin up faster, developing it's hp faster and the result is a much quicker hole shot. It just works......and once you are up and running, it just goes away,like it never existed !!!!! You don't have to buy that extra blade in the first place, and don't have to lug it around with you all the time (top end losses) either.
Thanks,
Mark
