Re: Say hallo to my leetle frand!
No, Mick! I should have clarified in the post: I always maintain that a simple carb change will not boost a 9.9 to a 15 or a 15 to a 25. This is not exactly true with larger engines.
In the case of this engine, the bore is only 3.187 for about 44 cubic inches. Later model Force 40 and 50 were 3.375 bore for about 50 cubic inches. These engines were able to utilize the big TC carb and in fact did come from the factory that way.
Your engine is 3.3125 bore with a total displacement of about 99 cubic inches, meaning each carb is servicing about 50 cubic inches. I have done this swap at least three times and there will be no adverse effects on your engine. The engine in my avatar is a 105 with the same displacement as your engine and TC carbs. With your engine it will be more like installing a 4 barrel on a Plymouth 318--It won't make it a world beater at the track without changing heads and cam etc. but it will pep it up some and make it honest.
I am hoping that when you finally do run it you will see 1-2 MPH more and not just equal performance. Oh, yeah, I forgot to mention: With the big carbs you can open up the reed stop plated about another 2 MM each side. This allows the reeds to open more and (hopefully) delivers more air. One of the differences between Chrysler engines with WB carbs and TC carbs IS the opening of the reed stop plates.
You can also cut these stop plates in half to eliminate or reduce any possible reed sticking (to the plate thus increasing blowback) Or you can drill the stop plates like the later Force models. Actually changing to the later square tipped Force reeds will not increase performance over the round tipped reeds on the Chrysler 4 Cylinder engines. I proved that a couple of years ago on my 140.
TC 5 carbs will have a jet size of around .092 to .096 depending upon model.
