Re: SEA FOAM
First of all, we're talking about boats here, and I'm pretty sure there isn't a single boat in the world with a catalytic converter.
Also it is not meant to be left in your oil full time, you put it in before an oil change and let it idle for a few minutes....
Snake oil is a term used for something that claims to work and does not. This stuff claims to work AND does work as advertised, therefore it is not "snake oil".Originally posted by BillP:<br />Snake oil...<br />When putting that stuff in your car gas be ready to plug up the catalytic converter. The additives may not do it but the chunks of unburnt crud that hit the converter can. Read up on converters and ask your local registered converter shop about it. They love to see people dump additives in the gas or spray it into the carb. Too much and it plugs everything up. It's your guess how much is ok.<br /><br />Also, there is no way thinning your crankcase oil with solvents is good for a motor under full time use. Do you want starved lubrication? It doesn't work both ways. You'll find this out when the motor reaches less miles than an engine that never used additives. My local auto mechanic's business is being warranty rep for Jasper and AutoZone engines. It's interesting to hear his stories about additives.
