Re: Sea King 5hp Reapir Manual
Since that's one of the later ones it's like the later Johnny/Rude 5.5hp engines (Johnny CD series, Evinrude "Fisherman"). Just get a prop for one of those. They pop up from time to time on ebay. Search for:<br />(5.5, 5.5hp) (Johnson, Evinrude) propeller<br />Alternatively, Iboats will sell you a shiny new one with a good hub for a mear $66. Use the 8 x 7.25".<br /> <br />The starter - is that the one with the nylon pawl that sticks out and engages the raised edge at the rim of the flywheel? Is the pawl not moving when you pull the rope? Sometimes they just need a good cleaning, but be careful removing the hub because the recoil spring which runs between the housing and rope pulley can be very dangerous.
