Seafoam. Any Good?
artherm
Re: Seafoam. Any Good?
I have used this product with very good results. It hasn't been mentioned, but you can buy the aerosol of this product "Deep Creep" at O'Rielly Auto Parts, nationwide.
You can spray directly into the intakes for cleaning, and they also recommend for winterizing and fogging.
Texasmark
So today I am pruning trees as it is the dormant season and time to do it.
Crank up the old chain saw with the deep creep in the fuel. Set the saw down for extended periods of time as I clean away limbs that I had just cut off.
Used to be the saw would idle for a minute or two and die. Nada. Runs till you pick it up, goose it, and hit another limb.
If you don't use this stuff in your equipment you are a looser................................I didn't say that.
Mark
samo_ott
casi77, thanks, I found it at the NAPA. Once I found that they had moved the NAPA to Industrial! Now I have yet to use it.
