Hi guys,
So I did the seafoam deep decarbonizing on my 25hp 1987 2-stroke Mariner #0B211923 hoping to increase compression (psi).
I did the whole 1 gallon of gas/oil mix and one 16oz can of seafoam in a small auxillary tank and threw the earmuffs on it and ran it on and off for about 15 min intervals a bunch of times.. Never overheated or anything just blew lots of smoke. Actually ran cool on low idle.
SOOO I decided to take it for a test run on the lake. Switched tanks over to my normal gas tank... used the same 12ft gas line... (probably should have drained the seafoam rich gas from the line before use).
I idled for a little bit and then attempted WOT and just before I got to full speed I had major loss in power... I cut the throttle and put my hand on the pee hole and it was really hot. Cut the engine kicked on my trolling motor and trolled back to the boat ramp.
When I got home I cleared the gas line and ran it with normal gas/oil/b-12 in the tank for a while as to clear any seafoam enriched gas from the system. I will test at the lake again tomorrow.
My questions are as follows:
1 - Would seafoam enriched fuel cause my engine to overheat at WOT? (1 can of seafoam to 1 gallon of gas mixture) (i think yes)
2 - Is a sudden loss of power at WOT a symptom of overheating??? Or phrase it this way - Could overheating cause a sudden loss of power when approaching WOT.
3- I added B-12 CHEMTOOL to my main tank. Do these fuel additives make my engine run hotter than norm? Will it hurt it?
4 - After a major Decarb is it normal to have a little less compression? At least untill all the carbon that's been knocked loose has worked it's way out of the system???
Thanks for all your help.
Nick
Nick
