searay drain plug?
Status
Not open for further replies.
Shaun78
Not sure where to post this.......My drain plug only screws in a few threads and then it's tight. The plug end sticks way out. Is this normal or should it screw in almost flush?
starsnstripers
Re: searay drain plug?
Auh? Or how? Drain plug? Water, hull, bildge, Oil, cooler, live well, portapottie, or?
Don S
The normal garboard drain plug is 1/2" NPT pipe thread, and usually go in about 1/4" to 3/8"
They don't screw in flush.
Robj
On my boat the plug is 1/2 inch NPT. The thread is tapered and seals itself. As long as it is not leaking you should be OK.
Have a great day,
Rob.
SgtMaj
There are threaded drain plugs? Sorry, I've only seen the rubber ones you just stick in and clamp down the handle which expands the center to make it watertight.
Ayuh,.......
Larger, or high-end hulls tend to have the Screw-in Garboard Plugs rather than the ole Coleman Cooler style of flip-over Rubber plugs.....
Shaun78
Thanks, I'm sure that I'm allset then.
steve1100
Sorry, I am new to this boating stuff. Where do I find the garboard drain plug?
Status
