sears 7.5 gamefisher fuel issues
michael s.
i have a sears gamefisher that i can't keep running . it will crank but only run for a few seconds and shut off could this be a float issue?
i just rebuilt the carb abd the fuel pump is good too i just replaced it last year . any advice would be a great help
M
mrcrabs
Guest
Re: sears 7.5 gamefisher fuel issues
Could be float or more likely fuel pump and flapper valve, I usually would recommend a carb kit, replace fuel lines and add a in line fuel filter, something like this kit on ebay
http://cgi.ebay.com/ebaymotors/ESKA-SEARS-COMPLETE-FUEL-PUMP-CARBURETOR-KIT-73-T-1984-_W0QQcmdZViewItemQQhashZitem3ca863adccQQitemZ260523142604QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
or call the people at www.certifiedpartscorp.com...they bought all of the eska stock and have every thing you need but you will have to call them.
M
mrcrabs
Guest
their's a tecumseh manual floating around here, so you need to ask for that as well....recommended reading before and during the carb rebuild
michael s.
yes i read some other posts and have requested the manual from cheapboatkev so hopefully i can get it soon and can use it
