Frank Acampora
- Jan 19, 2007
- 12,004
A Bridgeport mill would have made my life easier but the drill press will do.
Here we have my latest project, started on a whim. It is a three cylinder, 85 horse Chrysler from the late '70s. The first two photos show the interior of one cylinder and the porting I have done. This is not my usual mode. Typically I leave all four ports and thin the webs. This time I decided to eliminate two inter-port webs. Having larger bypass ports does no good if the bypass channel does not have adequate area and volume and can not service them so I added two lower ports that will open to two matching ports in the piston skirt.
The third and fourth photos show the same port treatment on the exhaust side. Only one port has been done so far. I am also contemplating adding a 1/2 inch spacer plate under the stainless one to add exhaust chamber volume and reduce backpressure. That's a lot of work though and could be added after the engine is running so---
The engine will be bored .030 over, (you can see a nice groove in one cylinder wall) will have Prestolite ignition and I am also contemplating increasing the compression.
Next summer I will post results on whether or not this engine turns out to be a fire breather.
