I've finished the repairs on my 94 gallon aluminum gas tank. Had the welder put a plug into the small hole on the rear bottom edge. Turns out, this tank is 1/4" aluminum. No wonder it's so heavy. Anyway, I've covered the edges with 2 layers of epoxy and 1 1/2 oz mat. i put 2 thick layers of epoxy on all other surfaces. The tank was originally foamed in place with wooden triangles wedged in between the stringer and tank in several places. the wedges were then screwed into the stringers. Additionally, there were 3 sets of 2x4 (untreated) across the top of the tank. these were also screwed into the stringers. I plan on securing the tank in the same fashion, but i have a foam question. How do I prevent the two part foam from going underneath the tank as its poured in?
