Re: Serial # plate gone - don't know yr
If you have an outboard, you do not have an "L" model.<br />An "L" model is an "L drive", which has the powerhead mounted inside the boat, much like an inboard.<br /><br />Each model year has several variations, some were improvements, some variations were just to use up parts in the warehouse.<br /><br />Example: Model 1206F9A was produced with certain components.<br />Then later in the year, when they ran out of some parts, they substituted a different part and called it model 1206F9B. Then even later in the year they produced a motor with different parts and called it 1206F9C.<br /><br />Other companies did the same thing, but Mercury did it alot just after they bought the FORCE line.<br /><br />I think the biggest differences with those models will be the ignition systems.
