Tominator88
- May 10, 2023
- 38
But will the HX behave? See if you can push it towards the belt to see how much travel it has if it's vibratingMake sure the heat exchanger is secured properly. Run it to see if there are any chaffing marks after a while. It may be OK. Serpentine belts tend to be better behaved than V belts because of the tensioner.
Yeah - willing to bet someone stepped on the heat exch or was laying on it. Wonder if it can be tweaked back a bitBut will the HX behave? See if you can push it towards the belt to see how much travel it has if it's vibrating
the engine coolant antifreeze 50% and the water distilled 50% of the heat exchange ... my engine is very good ...hello all, im in the middle of installing a new closed cooling system and my serpentine belt looks awfuly close to the heat exchanger does anybody have an opinion or rule of thumb for this sort of thing? any input could be helpful thanks,View attachment 399483
thsts a good idea ill try that. going to start for first tine this weekendBut will the HX behave? See if you can push it towards the belt to see how much travel it has if it's vibrating
