I read you can use a vacuum port on an auto carb to set the idle mixture screws.
I obviously dont have a vacuum port on my marine Edelbrock but is the port on the intake manifold a vacuum location I could use? Im talking about the one that has a hose going to it from the starboard side valve cover. Has a PCV valve in there.
I tried doing it by ear but I dont think I am doing it right. By the time I can tell if the engine is stumbling the screws are way out or way in.
The best I got it to be was exactly 2 turns out which I was turning them to as a starting point since I had turned them so much.
I have a timing light that is a tach too. 2 turns out is where I get the highest idle. If I go in the idle becomes eratic and goes down. If I go out the idle does not increase. If I go way out it will stumble.
2 turns out is where the RPM stays nice and steady.
