Re: setting Low Speed Jets
With the boat in the water, engine warmed up and in fwd gear, you can individually tune each carb for smoothest and fastest idle. The motor will speed up as you turn an idle screw in (lean) until it "sneezes" as described in a previous post. It'll slow down and "burble" if it's too rich.<br /><br />Once you find the best, fastest, smoothest idle point, this adjustment will probably make it bog upon acceleration. At this point, adjust all 3 idle screws equally CCW (rich), 1/8 turn at a time until it doesn't bog. <br /><br />The idle may be a tad lumpy after the final adjustment, but that's about as good as you're going to do on these old Beasts! You may have to adjust tweak idle speed stop, such that the motor's running fast enough to maintain a stable idle in gear.<br /><br />Once you have it tweaked in, she should run real strong for you.<br /><br />HTH........ed
