noideawhat
- Mar 29, 2013
- 79
If I can't fix the problem that is what this thread will end in.
I took it out of storage had it runnin it was fine. I put it in water for the spring test run and it started fine. Drove about 100 meters with throttle atalittle over idle and kaput, nothing, it just stalled and woundt start again. It'll crank just won't start
Also I am a total newby here and literally have no clue what I'm doing
I did notice almost like a pressure sound comming from the right lower end of the motor. Almost like there's a pin prick in the water jacket,
Either way I jb welded the spot (only because it was so small)
Any advice here would be great maybe aome suggestion on what it could be.
