Shaft shaft height
Thanks....going over someone else's work on a used lower unit ...need to pull apart see What's up....
Right...no it's a used lower unit that someone installed and its just is getting reverse and the cable is as the end of adjustment ..think the shift cradle is bent or broken because 21 15/16 is not working...going over some ill work by someone else
Just take it apart.----Post pictures of the parts.----I don't think a shift cradle can bend on these !
