Texasmark
- Dec 20, 2005
- 14,946
Re: shear pin issues
The pin that goes through the prop shaft after the prop is installed is actually a drive pin.....it connects the prop to the drive shaft so that it can be driven.
Just so happens it breaks (shears) when some hard objects are struck, hence the jargon term "shear pin".
In reading the replies I had a couple of thoughts. It is possible that the brass insert in the rubber hub has wallowed out and this could allow for some slack that is undesirable.
Next, it is possible that the rubber "slip hub" no longer slips when obstructions are struck, hence the shear pin takes the whole load.
Since the prop is dinged up already, the correct OEM pin and a new prop may solve the problem.
My 2c,
Mark
what is the diffrence between a drive pin and shear pin? Mine is like the one pictured.
My 2c,
Mark
