got boat in , after all the help I got from this forum ,replacing engine , gimble etc,, , must of did a good job with alignment as it fell out, to the question , seems I have the dreaded shifter cable problem, shifting in and out of reverse and now forward , dies, 95 merc 4.3 alpha 1, ser no on out drive 0f523375. do I have to pull hinge pins to install new bellows when I change cable, the bellows look great but shouldnt I replace now? any tricks? the crimper they show you to make in manuel doesnt look like you could get it in there with other bellows on. also any body know correct part no, for bushing , seal kit for shift shaft, and merc cable kit? I have out drive off, everything looks straight forward, is the hardest part geting it thru the transome? any tricks , thanks again mac from nebraska
