shift cable help
Rob7Dawg
aq271 with dp290a
i finally got my boat on the water and i noticed i had sprung a leak. behind the motor i see water coming in through a hose and i follow it and see that it is for the shifting forward and reverse. it has a solid hard plastic line from the throttle, out the bottom of the boat, into the outdrive. from the bottom of the boat there is a hose going around it and it is about 3 foot long. i patched the hole with a rubber hose and clamp but i was wonder if water is sapposed to go into the hose or not.
its a dead end on the upper side of the hose.
zbnutcase
Re: shift cable help
It is very possible that the hose for the shift cable has sprung a leak, and it does exit below waterline, so yes there is supposed to be water in it. Better fix it before your boat sinks!
cr2k
That would be an OMC. Patch the hose and keep the inboard end above the water line.
