i recently purchased a boat a 1978 glastron, with a 70 hsp evunrude motor model # 70773s the problem i have is the control box, the reverse is in the neutral position and then pushing forward is neutral and then forward...i tried changing the position of the handle itself, figuring that would be the easiest to do, since you only have to remove the allen screw and reposition the handle.but ,when i did this i couldn't line it up with the groove under the handle, now, is it posssible to remove the outer cover and turn ,and line it up that way,or am i just thinking on the wrong page,any help would be appreciated..thank you
