Power plant is 7.4MPI with B3 [2001]. When first starting up if shift is moved from neutral to forward, clutch engagement is A-OK. If I have to back out of a space first and then move through neutral (I wait a second or so in neutral) and move to forward, I have to push the lever further (motor revs more) before clutch engagement (Is the problem in the shift cable or someware in the B3?<br /><br />Note: anyone with B3 and SS props in salt water add a second Mercathode controller in parallel with the original if you want to fully protect the drive. (What a difference when the field voltage is above .9V).
