Shift rod adjustment.
_brad_
OK so my manual is in the mail.
Replacing water pump on 1977 70 HP Evinrude. I think I messed with the shift rod a little and now it may be out of alignment.
Any general thoughts on proper measurements for shift rod prior to reinstalling?
Thanks
Joe Reeves
Re: Shift rod adjustment.
1976 - 1977 - 70, 75hp (L) 21-25/64" plus/minus 1/32". Have shift rod in neutral.
Measurement taken from the top surface of the lower unit to the center of the shift rod hole.
_brad_
One thing just came to my mind in regards to this.
I have a Johnson lower unit installed on this 1977 70 HP Evinrude. The measurements above are for an Evinrude motor.
Are the specifications for shift rod length going to be different for a unknown year Johnson lower unit?
