Can anyone tell me if shifting into reverse on my Legend boat with a 60 hp merc should be any stiffer than shifting into forward? I removed the cable from the engine and the shifting lever moves easily compared to having the cable attached.I just finished installing a water pump kit and wonder if I created this issue.I had the boat running since installing the pump kit and it is stiff going into reverse running also.Any input will be greatly appreciated.
