shifting problem
tashasdaddy
your idle is either too high, or you cable are binding, or going bad. docking should be done very slow, reverse is not a brake. and no you should not go the reverse when going fast, you will take out the lower unit. do you shift into reverse in the car going fast?
mattttt25
Re: shifting problem
ok, take away his last comment. but he's correct- idle too high or cables binding. check idle first, then go through your controls manual and adjust accordingly.
