boater184
- Oct 16, 2013
- 15
My 1989 Bayliner Cierra shore power keeps blowing the gfi outlet on the dock, different gfi's, so I'm sure its not the dock power, especially since other boats are hooked up with no problem. So when I first plug in, with all the breakers turned off and the master power switched turned off, its fine, however the green power indicator light glows and flickers very faintly. As soon as I turn on the main breaker, even with the individual breakers still off, it breaks the Gfi circuit. The cable is good, and I have replaced the cable receptacle on the boat. This spring when I first launched it all worked fine, then after a few weeks it started blowing the Gfi.
What gives, is the very faint indicator light a tell-tale something that could be wrong ?
