Re: shopping list for flooring project
Boater, have you torn into anything yet? I highly recommend whipping out the circular saw/chain saw/angle grinder, or other weapon of choice, and opening that bad boy up. Now is the time to know the status of yout transom and stringers so you know if they need to be replaced as well. The stringers are what supports the floor, they run from the transom to the bow. There are between two and six of them, they are glassed to the hull botom and the transom. The foam is between these stringers.<br /><br />The floor is resting on top of the stringers, sometimes they were nailed or screwed down, but more often there is just a strip os fiberglass mat between the floor and stringer tops. Around the top of the floor, where it meets the sides and transome, there is a strip of fiberglass mat or cloth, and then the entire floor surface is sheathed in fiberglass mat or cloth. This sheathing covers the entire floor surface, and extends up the sides and transom about six inches, covering the strip that also holds the floor to the sides and transom. <br /><br />I have to replace the floor, transom, and stringers, so I ended up having to get 8 gallons of resin and 30 square yards of mat so I can glass everything in. I am not using carpet, due to the water retention possibility. Instead, I found a product that is a non-skid rubberized product that will act to seal the floor and be easy to clean. good luck, and post some pics if possible....
