Short or long water pump?
AList233
'94 5.7Gi PHUS. Does it run a short or long water pump. The pulleys are rusted to the point I'm just going to replace them.
jimmbo
Contact a Volvo Dealer, they should be able to get you the correct pump
Bt Doctur
Most GM pullys are short but some use a larger diameter
Post a pic, might have one
While the Volvo engine uses GM pulleys. You won't find them in an automotive equivalent
Either visit your GM industrial dealer or order thru Volvo
Me personally, would soak the pullies in oxalic acid for a week (to remove all the rust). Wire brush them and paint them.
Your out maybe $20
jimmbo
If the pullies weren't rotted through, I would just wire brush them and spray a coat of Rust-oleum or Tremclad
